I have problems to set up a calculation using the radiation module in CS. In my case I added all user subroutines for radiation (usray1-5) into my SRC directory, because I do not use a specific physics module. In usray1 I activated iirayo=1 for the DO method. If I started the calculation I get an error massage ( see the attached listing file ). There are three heading in sbr. usray1, ipass=1,ipass=2,ipass=3. The settings for isuird, nfreqr,ndirec,idiver,…and so on are done in heading 2 (ipass2) but I believe that these parameters are used in the code before they are set in usray1 (ipass = 2). What do I have to do to activate the radiation module correctly. Is there anything else to specify in other subroutines, like usini1?
Thomas Aumeier
listing.txt (7.94 KB)
