I have a very newbish problem: Everytime I try to launch a test calculation Im struck with the following error message:
WARNING: BOUNDARY CONDITIONS ERROR
@ In the zone out has a face already marked
@ with a zone number.
@ new zone number: 2
@ previous zone number: 1
@ It seems that zones definitions are overlapping.
@ The calculation will stop.
The zones I’ve given in Definition of BCs are simply 1,2,3 for surface groups in, out, and wall - I’ve tried changing the zones to numbers 4,5 and 6 with the same error appearing.
The mesh is a very simple one created in Salomé for testing; I’ve attached it here.
Heres the BC section from the XML
<boundary_conditions>
<boundary label="in" name="1" nature="inlet">all[]</boundary>
<boundary label="out" name="2" nature="outlet">all[]</boundary>
<boundary label="wall" name="3" nature="wall">all[]</boundary>
<variable/>
<scalar/>
<outlet label="out"/>
<wall label="wall">
<velocity_pressure choice="off"/>
</wall>
<inlet label="in">
<velocity_pressure choice="norm" direction="normal">
<norm>1</norm>
</velocity_pressure>
<turbulence choice="hydraulic_diameter">
<hydraulic_diameter>1</hydraulic_diameter>
</turbulence>
</inlet>
</boundary_conditions>
Mesh_2.med.gz (28.3 KB)
