I am searching for opinions about the basic setting to run simulations in atmospheric flow on an urban case (squares of 800m/800m), I want to share with you what setting I am applying:
turbulence model: k-epsilon steady flows
No thermal scale physical properties (no changement for what is put by default)
boundary conditions generally:
// upper part and lateral part of the vein are symmetric // buildings roof (wall - smooth) building’s wall (wall - roughness height 0.0025) // down the surface of the vein (wall without roughness) -
INLET: logarithmic profile + turbulence formula relaxation of pressure increase = 1.0 velocity - Pressure algorithms: Simplec
nb of iteration: (300 sometimes 900)
I include a set of mounting points and I do generally a parallel computing on 4 cores
Number of cells: 3114820
I have 3 questions:
1/ Do I have to check or change another parameter in code Saturne according to the atmospheric flow?
2/ If I want to use a power law for velocity, do I have to change the formula of the turbulence or I can use the same for the logarithmic profile
3/ For the monitoring points I am interested in the evolution of their velocity, but what I get (velocity x, velocity y, velocity z), is there a way to get the magnitude velocity (vitesse résultantes)?
4/ For the boundary condition is there a way to put “slip boundary condition”, what is the difference between slip condition and symmetry conditions?
I will be so glad for any opinion or discussion about the setting, thanks for any help
Houda
