Convergence tool
I have install CS 7.2 on Ubuntu 22.04. I use the GUI of CS.
Convergence tool is not running during calculation. If I press the convergence tool button, nothing happens. I have follow Tjunction tutorial case.
How can I fix that?
You are not alone. I have the same problem.
  File "/home/wing/Apps/saturne-7.2.dbg/bin/code_saturne", line 94, in <module>
    retcode = cs.execute()
  File "/home/wing/Apps/saturne-7.2.dbg/local/lib/python3.10/dist-packages/code_saturne/base/cs_script.py", line 96, in execute
    return self.commands[command](options)
  File "/home/wing/Apps/saturne-7.2.dbg/local/lib/python3.10/dist-packages/code_saturne/base/cs_script.py", line 169, in trackcvg
    return cs_trackcvg.main(options, self.package)
  File "/home/wing/Apps/saturne-7.2.dbg/local/lib/python3.10/dist-packages/code_saturne/gui/cs_trackcvg.py", line 132, in main
    mv = MainView(cmd_package = pkg, cmd_case = case)
  File "/home/wing/Apps/saturne-7.2.dbg/local/lib/python3.10/dist-packages/code_saturne/gui/trackcvg/MainView.py", line 1275, in __init__
    self.timer.start(self.timeRefresh * 1000)
TypeError: arguments did not match any overloaded call:
  start(self, int): argument 1 has unexpected type 'float'
  start(self): too many arguments
Looks like some tricky incompatibility with python 3.10 because it works well with python 3.6.5 even in Ubuntu 22.04.
By the way, in python 3.10 $cspath is set to $cs_root_dir/local/lib/python3.10/dist-packages rather than $cs_root_dir/lib/python3.10/site-packages. It’s not the cause of this problem but still it’s weird.
I have check the pathes of python 3.10, in the file code_saturne_build.cfg, it is written:
pythondir: /usr/local/local/lib/python3.10/dist-packages
pkgpythondir: /usr/local/local/lib/python3.10/dist-packages/code_saturne
There is nothing wrong, the folders exist
Do I need to use python 3.6.5 insted ? How can I do that?
Julien
I checked and found the problem, which is due to some timer quantity expecting an integer and receiving a floating-point value in recent PyQt versions (I did not check whether Python or PyQt is the cause).
The fix is pushed to GitHub for the master and v7.2 branches. So if your 7.2 build is based on a git clone, simply update and rebuild. Otherwise, the fix is simple, so you can do edit it manually if you really need to: https://github.com/code-saturne/code_saturne/commit/b52675d9f67146fa65b213ce51fe0a46e4bef607
The commit works for 7.2 in Ubuntu 22.04. By the way, 7.0 also has the same problem and modifying the python script manually solves the problem.
I have update 2 files named MainView.py but the problem still persist.
Do I need to do something more?
Attached the MainView file
Julien
MainView.txt (46.2 KB)
Still not working for me.
I change the 2 files MainView.py located in
  • Home/Code_Saturne/code_saturne-7.2.0/python/code_saturne/gui/trackcvg
  • Home/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/gui/trackcvg
Maybe I need to rebuild something?
Julien
Did you try running
“code_saturne trackcvg”
alone or only wih the GUI ?
If you run it alone, what error message do you have ?
The error message is
julien@julien-virtual-machine:~/Travail/test_cyl1/RESU/20221119-0915$ code_saturne trackcvg
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
File “/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/bin/code_saturne”, line 94, in
File “/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/base/cs_script.py”, line 96, in execute
return self.commandscommand
File “/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/base/cs_script.py”, line 169, in trackcvg
File “/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/gui/cs_trackcvg.py”, line 132, in main
File “/home/julien/code_saturne/7.2.0/code_saturne-7.2.0/arch/Linux_x86_64/local/lib/python3.10/dist-packages/code_saturne/gui/trackcvg/MainView.py”, line 1277, in init
start(self, int): argument 1 has unexpected type ‘float’
Julien
It seems your installation is still using the old (non-corrected) code. Did you reinstall after patching the sources ?
I have only modify directly the files MainView.py
You need to reinstall the code after this, so at least re-run “make install”.
I am sorry for the stupid question again, but I don’t succeed to do this.
I run in my build directory.
$ ../code_saturne-7.2.0/configure
$ make
$ make install
make install need to be done with high permission level is it normal ?
The re-install takes several minutes but in the GUI convergence tool does nothing.
Remember that I have only change manually lines in the MainView.py files. Nothing downloaded on github.
I try to reinstall in the semi automatic way “install_saturne.py”. Same result
Could you tell me a more precise procedure please?
I could reinstall everything from the main download link on the code saturne website, the change in is done in MainView.py file if I do this?
Julien
The GitHub v7.2 branch is up to date and contains the fix, but there has not yet been a new release (7.2.1) with the fix, so the download from the main web site will not contain anything new.
You do not need administrator privileges if you install to a directory you are owner of (such as anything under $HOME).
The installation guide provides much more information if you need additional details.
It is strange that you still have te bug. Dis you check the Python file (MainView.py) in the install matches the one you modified ?
I have delete all the code_saturne folders in my $HOME.
I have restart from the beginning the installation with “install_saturne.py” (the only way I can manage to install CS…)
I have still the error…
Do I need to uninstall CS with a command line. I have installation files referring to CS in $HOME/usr/local
Julien
Ok it works now.
The files that I had modified was not good…
