As per the forum recommendations, could you post a bit more info ? Your xml file possibly cs_user_script.py files, as well as the preprocess.log file would be a start, and passing the output of “ls” in the execution directory would provide more info.
Did you read the preprocessor.log ? It seems to end prematurely (no “normal end” or error message), so I do not know what happened, but either the end of your posted file is missing, or there was an undetected preprocessing error.
Did you test the same mesh with a previous version of Code_Saturne ?
As your mesh seems to be is very small, could you post it here ?
Yes, I read the preprocessor.log, and the fact that a “fin normale du préprocesseur” was missing surprised me, but I thought it was a specificity of this new version…
I first used a .msh mesh, that I also converted to .unv format. This latter works (preproc OK, calculation OK).
The .msh mesh should still work, or lead to an error message, so as it seems there may be a bug, we are still interested in your .msh file (either on the forum or by private message or sent to the saturne-support at edf dot fr if it is confidential), so as to check it and debug the code if necessary.
I’ll push the fix under version control tomorrow, so the bug will be fixed in bug-fix release 3.0.1 (which we’ll probably release within a few days; I’m just waiting for a few minor GUI-related bug fixes.
