I am using code_saturne 2.2.1. I tryed to get some time averaged outputs using the interface GUI but i’ve been surprised by the results. It seems to be that the output values are not divided by the total time averaging interval. This problem is not present in the listing output but only in postprocessing outputs.
Kamel.
Are you using a variable time step ? Another user has reported a similar bug, so I will try to fix this next week.
It hapens for both constant and variable time step.
Kamel.
