Hi
I am having trouble installing MED
this is what I am getting :
please help
note that HDF5 and cgnlib have been successfully installed
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for a thread-safe mkdir -p… /bin/mkdir -p
checking for gawk… no
checking for mawk… mawk
checking whether make sets $(MAKE)… yes
checking whether make supports nested variables… yes
checking how to create a ustar tar archive… gnutar
checking whether to compile using MPI… no
checking for style of include used by make… GNU
checking for gcc… /usr/bin/cc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… no
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether /usr/bin/cc accepts -g… yes
checking for /usr/bin/cc option to accept ISO C89… none needed
checking dependency style of /usr/bin/cc… gcc3
checking for /usr/bin/cc option to accept ISO C99… none needed
checking build system type… x86_64-unknown-linux-gnu
checking host system type… x86_64-unknown-linux-gnu
configure: Can’t find a parallel version of HDF.
checking how to run the C preprocessor… /usr/bin/cc -E
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking absolute name of <H5public.h>… checking H5public.h usability… yes
checking H5public.h presence… yes
checking for H5public.h… yes
///home/sofiane/Code_Saturne/4.0.6/hdf5-1.8.14/arch/Linux_x86_64/include/H5public.h
checking absolute name of <H5Ipublic.h>… checking H5Ipublic.h usability… yes
checking H5Ipublic.h presence… yes
checking for H5Ipublic.h… yes
///home/sofiane/Code_Saturne/4.0.6/hdf5-1.8.14/arch/Linux_x86_64/include/H5Ipublic.h
checking for H5open in -lhdf5… no
configure: error: either use HDF5HOME env. var. or --with-hdf5=
Could you provide the other recommended info (install method, logs, …as per the forum guidelines) ?
Hi
Attached
install_saturne.log (2.18 KB)
You still did not specify whether you used the automatic installer or the MED configure directly.
If you used the installer, could you specify your setup file ?
In any case, if you export HDF5HOME to the HDF5 path before running the install, the issue should disappear (though this should not be necessary).
Hi
I did and I hope it is the right way
export HDF5HOME=/home/sofiane/Code_Saturne/4.0.6/hdf5-1.8.14/arch/Linux_x86_64
echo $HDF5HOME
but still have the same error when installing MED
Please help
Sofiane
could you post the “config.log” from the MED build directory (a subdirectory in the Code_Saturne build if you used the automatic installer) ?.
I have attached it
I am using the setup file and executing the install_saturne.py
config.log (21.1 KB)
It seems the error is due to a missing “-lz” library. So you must install libz and its headers.
Which type of system are you running on ?
Hi
I am using Ubuntu 16.04 LTS
Not sure of the package’s name on Ubuntu, but I think it is libz4g-dev.
Hi
I have installed zlib1g-dev the i got another error while installing MED
I solved it with installing python-dev
no I have another problem with the installation of scotch
I have attached the log. I did install mpi but in vain
Sofiane
install_saturne.log (294 KB)
Could you please provide the other details as per the forum’s recommendations ?
You seem to be missing MPI development headers.
sorry
I attached the config.log
config.log (196 KB)
Scotch is optional, and sometimes a pain to install (especially when we try t automate that step), so if you have issues with it, you can opt not to use it in the setup configuration.
Hi
I did. Hope it will not limit the capabilities of the code version i will use
I moved to parmetis and i have got an error during the installation
I attached the files
Sofiane
install_saturne.log (150 KB)
config.log (196 KB)
As I said in a previous message, you are missing mpi.h. You need to install MPI developement headers (openmpi-dev or mpich-dev or something similar) if you want to compile with MPI.
I did
/usr/include/mpich/mpi.h
the installation script fails to locate it
how can i get around this problem?
Sofiane
Again, what do you have in the installer’s “setup” file ?
Hi
both mpiCompcxx and mpiCompc are set as auto
I have attached the setup
Sofiane
I believe you forgot the attachment.
