Hello, I wonder if there are modules for fluid-structure coupling in the code _ saturn ?
Thank you very much.
there is actually a module which allows internal structure coupling. But an external coupling with Code_aster is under investigation.
Mickael
What is called the module of internal coupling structures ? i am using now the 2.0.2 version of code_saturne.
Thank you.
Nazir
I think i found these modules are : usstru.f90
usstr1.f90
usstr2.f90.
Routines requested for internal coupling are usstru.f90, usalin.f90 and usalcl.f90.
Take note that you can do lot of things through the interface with the version you are using currently.
Mickaƫl
