fonction main() can't be found
I have the problem to install the code-saturne 1.3.3. In fact , the code can begin and finish the calcul normally, but there are not resultats in the file RESU neither in the file tmp_saturne.
The file compil.log showed
Version of compilers used
FORTRAN Compiler
*** Code_Saturne 1.3.3 compilation/link
*** System: NetBSD
*** Compilation
foo.F
f77 -D_CS_HAVE_XML -v -c foo.F
Reading specs from /usr/pkg/gcc3/lib/gcc-lib/x86_64–netbsdelf2.0/3.3.6/specs
Configured with: ./configure --prefix=/usr/pkg/gcc3 --host=x86_64–netbsdelf2.0 - -enable-shared --enable-languages=f77
Thread model: posix
gcc version 3.3.6
/usr/pkg/gcc3/lib/gcc-lib/x86_64–netbsdelf2.0/3.3.6/cc1 -E -traditional-cpp -D_LANGUAGE_FORTRAN -quiet -v -D__GNUC__=3 -D__GNUC_MINOR__=3 -D__GNUC_PATCHLEVEL__= 6 -D_CS_HAVE_XML foo.F /pmmh2/tmp/openmpi/ccJAJ9pS.f
ignoring nonexistent directory “/usr/pkg/gcc3/include”
ignoring nonexistent directory “/usr/pkg/gcc3/x86_64–netbsdelf2.0/include”
#include “…” search starts here:
#include <…> search starts here:
/usr/local/include
/usr/pkg/gcc3/lib/gcc-lib/x86_64–netbsdelf2.0/3.3.6/include
/usr/include
End of search list.
/usr/pkg/gcc3/lib/gcc-lib/x86_64–netbsdelf2.0/3.3.6/f771 /pmmh2/tmp/openmpi/ccJ AJ9pS.f -quiet -dumpbase foo.F -auxbase foo -version -o /pmmh2/tmp/openmpi/ccgGai kB.s
GNU F77 version 3.3.6 (x86_64–netbsdelf2.0)
compiled by GNU C version 4.1.3 20080704 prerelease (NetBSD nb2 20081120)
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 as -V -Qy -o foo.o /pmmh2/tmp/openmpi/ccgGaikB.s
GNU assembler version 2.16.1 (x86_64–netbsd) using BFD version 2.16.1
*** Compilation finished
*** Linking
libpath=-rdynamic/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib:/usr/local/sat urne/opt/bft-1.0.8/arch/NetBSD/lib:/usr/pkg/lib:/usr/pkg/lib:/usr/local/saturne/o pt/bft-1.0.8/arch/NetBSD/lib:/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib:/u sr/pkg/gcc3/lib
cc -o “cs13.exe” -v foo.o -L/usr/local/saturne/Noyau/ncs-1.3.3/arch/NetBSD/lib -L/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib -R /usr/local/saturne/opt/fv m-0.12.0/arch/NetBSD/lib -lfvm -L/usr/local/saturne/opt/bft-1.0.8/arch/NetBSD/lib -R/usr/local/saturne/opt/bft-1.0.8/arch/NetBSD/lib -lbft -rdynamic/usr/loc al/saturne/opt/fvm-0.12.0/arch/NetBSD/lib:/usr/local/saturne/opt/bft-1.0.8/arch/N etBSD/lib:/usr/pkg/lib:/usr/pkg/lib:/usr/local/saturne/opt/bft-1.0.8/arch/NetBSD/ lib:/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib:/usr/pkg/gcc3/lib -L/usr/pk g/lib -R/usr/pkg/lib -lxml2 -pthread -L/usr/pkg/lib -R/usr/pkg/lib -lmpi -lopen-r te -lopen-pal -Wl,–export-dynamic -lutil -lm -L/usr/local/saturne/opt/bft-1.0.8 /arch/NetBSD/lib -R/usr/local/saturne/opt/bft-1.0.8/arch/NetBSD/lib -lbft -L/usr/ local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib -R /usr/local/saturne/opt/fvm-0.12.0 /arch/NetBSD/lib -lfvm -lm -lpthread -L/usr/pkg/gcc3/lib -lg2c
Using built-in specs.
Target: x86_64–netbsd
Configured with: /usr/src/tools/gcc/../../gnu/dist/gcc4/configure --enable-long-l ong --disable-multilib --enable-threads --disable-symvers --build=x86_64-unknown- netbsd4.99.72 --host=x86_64–netbsd --target=x86_64–netbsd --enable-__cxa_atexit
Thread model: posix
gcc version 4.1.3 20080704 prerelease (NetBSD nb2 20081120)
ld -R /usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib -R/usr/local/saturne/opt /bft-1.0.8/arch/NetBSD/lib -R/usr/pkg/lib -R/usr/pkg/lib -R/usr/local/saturne/opt /bft-1.0.8/arch/NetBSD/lib -R /usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib - dc -dp -dynamic-linker /usr/libexec/ld.elf_so -o cs13.exe /usr/lib/crt0.o /usr/li b/crti.o /usr/lib/crtbegin.o -L/usr/local/saturne/Noyau/ncs-1.3.3/arch/NetBSD/lib -L/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib -L/usr/local/saturne/opt/bft -1.0.8/arch/NetBSD/lib -L/usr/pkg/lib -L/usr/pkg/lib -L/usr/local/saturne/opt/bft -1.0.8/arch/NetBSD/lib -L/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib -L/usr /pkg/gcc3/lib foo.o -lfvm -lbft -lxml2 -lmpi -lopen-rte -lopen-pal --export-dynam ic -lutil -lm -lbft -lfvm -lm -lpthread -lg2c -lgcc -lgcc_eh -lpthread -lc -lgcc -lgcc_eh /usr/lib/crtend.o /usr/lib/crtn.o
/usr/lib/crt0.o: In function ___start': : undefined reference to main’
*** Error code 1
Stop.
make: stopped in /pmmh2/tmp/jluo/tmp_Saturne/CONVERGE3D1.CASE_RE60.08081721/dir_compiler_f_version
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
No FORTRAN test executable
C Compiler
*** System: NetBSD
*** Compilation
foo.c
gcc -I/usr/local/saturne/opt/bft-1.0.8/arch/NetBSD/include -I/usr/local/saturne /opt/fvm-0.12.0/arch/NetBSD/include -I/usr/pkg/include -I/usr/pkg/include/libxml2 -D_POSIX_SOURCE -D_CS_HAVE_MPI -D_CS_HAVE_XML -DNDEBUG -v -c foo.c
Thread model: posix
/usr/libexec/cc1 -quiet -v -I/usr/local/saturne/opt/bft-1.0.8/arch/NetBSD/includ e -I/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/include -I/usr/pkg/include -I/u sr/pkg/include/libxml2 -D_POSIX_SOURCE -D_CS_HAVE_MPI -D_CS_HAVE_XML -DNDEBUG foo .c -quiet -dumpbase foo.c -mtune=k8 -auxbase foo -version -o /pmmh2/tmp/openmpi/c cJnfkYc.s
/usr/pkg/include
/usr/include
End of search list.
GNU C version 4.1.3 20080704 prerelease (NetBSD nb2 20081120) (x86_64–netbsd)
compiled by GNU C version 4.1.3 20080704 (prerelease) (NetBSD nb2 2008112 0).
Compiler executable checksum: af6330af6ff5af0c3bf1aa89b3101591
foo.c: In function ‘main’:
foo.c:3: warning: incompatible implicit declaration of built-in function ‘printf’ as -V -Qy -o foo.o /pmmh2/tmp/openmpi/ccJnfkYc.s
*** Linking
Thread model: posix
/usr/lib/crt0.o: In function `___start’:
: undefined reference to `main’
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
*** Error code 1
Stop.
C Compiler
*** System: NetBSD
*** Compilation
foo.c
Thread model: posix
/usr/pkg/include
/usr/include
End of search list.
*** Linking
Thread model: posix
*** Linking finished
*** Executable:
-rwxr-xr-x 1 jluo pmmh 8563 Aug 8 17:21 cs13.exe
C test program successfully ran
*** System: NetBSD
*** “make” in a user directory
*** Compilation
usclim.F
f77 -D_CS_HAVE_XML -I. -O1 -c usclim.F
usini1.F
f77 -D_CS_HAVE_XML -I. -O1 -c usini1.F
*** Linking
cc -o “cs13.exe” -O usclim.o usini1.o -L/usr/local/saturne/Noyau/ncs-1.3.3/arch/ NetBSD/lib -lsaturneBASE -lsaturneCFBL -lsaturneCOGZ -lsaturneCPLV -lsaturneELEC -lsaturneFUEL -lsaturneLAGR -lsaturneMATI -lsaturneRAYT -lsaturneBASE -lsaturne CFBL -lsaturneCOGZ -lsaturneCPLV -lsaturneELEC -lsaturneFUEL -lsaturneLAGR -lsatu rneMATI -lsaturneRAYT -L/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib -R /usr /local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib -lfvm -L/usr/local/saturne/opt/bft- 1.0.8/arch/NetBSD/lib -R/usr/local/saturne/opt/bft-1.0.8/arch/NetBSD/lib -lbft -rdynamic/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib:/usr/local/saturne /opt/bft-1.0.8/arch/NetBSD/lib:/usr/pkg/lib:/usr/pkg/lib:/usr/local/saturne/opt/b ft-1.0.8/arch/NetBSD/lib:/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib:/usr/p kg/gcc3/lib -L/usr/pkg/lib -R/usr/pkg/lib -lxml2 -pthread -L/usr/pkg/lib -R/usr/p kg/lib -lmpi -lopen-rte -lopen-pal -Wl,–export-dynamic -lutil -lm -L/usr/local/ saturne/opt/bft-1.0.8/arch/NetBSD/lib -R/usr/local/saturne/opt/bft-1.0.8/arch/Net BSD/lib -lbft -L/usr/local/saturne/opt/fvm-0.12.0/arch/NetBSD/lib -R /usr/local/s aturne/opt/fvm-0.12.0/arch/NetBSD/lib -lfvm -lm -lpthread -L/usr/pkg/gcc3/lib -lg 2c
*** Executable:
-rwxr-xr-x 1 jluo pmmh 4033275 Aug 8 17:22 cs13.exe
Someones have an idea for my problem? I 'm not good at fortran. Thanks a lot.
Best Regards
juan LUO
It seems the code compiled OK, but you have some other issue.
Is the tmp_Saturne file completely empty ? Otherwise, do you have a listpre, listing, or error file in tmp_Saturne/. ?
What message do you obtain on the screen when starting the code ?
Also, in any case, we recommend using Code_Saturne 2.0 rather than 1.3.
Thanks your answers. In the tmp_Saturne file there are: chr.ensight/ fort_saturne/ preprocessor_output/ compil.log listing resume converge3D1.neu listpre cs13.exe localexec the file which I joint above, it’s the file of compli.log. when I start the code it seems normal, and the code can finish the calcul normally. But in the file chr.ensight/ , there is only chr.geo, anything else. So I don’t known what is wrong.
For the version 2.0, we tried to install it before, but not succeed, so we have installed the version 1.3.3
Do you know why installation of 2.0 failed ? Could you try again (using the new documentation id necessary), and post your error logs if it still does not work ?
To determine what is wrong, you need to check the “listing” and “resume” files.
Thanks a lot Yvan, I will try it.
