Heated square tuto 3
I’m doing the tuto about heated square cavity flow.
The fact is when i modify the density :
b=0.0033;
tref=293.15;
density = rho0*(1-b*(temperature-tref));
My calculation is not converging, i plotted the density graph here it is :
Do anyone know what can be the matter ?
This may be due to different causes, but I can’t guess at which without more information.
I think I found the mistake, the scale was not good I was using a mesh in centimeter (1100100) instead of meter (0.0111). :laughing:
I tell you back if there is other problems
Thank you
