mapped inlet for LES simulation
I’m using version6 to run a LES simulation. There is an inlet in the simulation domain, and I have an extra inlet pipe where I can apply the mapped inlet function to create fully developed turbulent flow for the real inlet. I noticed that the mapped inlet can be defined through both GUI and subroutine. In the subroutine, I can specify the variables to be copied to the inlet, but in the GUI, it seems like I cannot select which to copy. So if I just define the mapped inlet through GUI, is code_saturne copying all the variables or just copying the velocity to the inlet?
Huang
Using the GUI, all variables are copied.
Note that the mapped inlet is fine for RANS, but for LES, our main turbulence specialist thinks it would be better (when the inlet and the section it is mapped to are conforming) to copy values from face centers instead of cell centers for better consistency. I am not sure we have much feedback using it in LES so I guess it is still worth a try.
Also note that by default, most values (velocity, scalars, …) are rescaled to make sure iterpolation error does not progressively damp or amplify values, but turbulent field values (in RANS) are not, as it would defeat the purpose. In LES, that second aspect is probably not important. In any case, this can also be controlled more finely using user
functions, while default apply with the GUI.
