Hi
I’m try to run my first simulation in code_saturne.
I prepared a simple mesh with Gmsh, then trying to use the preprocessor to import the mesh.
this is the log file I got:
| Code_Saturne Preprocessor |
code_saturne version 5.0.9 (built 09/26/18 18:45:31)
CGNS 3.1.4 file format supportThe description of point <2> was expected in the form "label x y z".
MED 3.2.0 (HDF5 1.8.12) file format support
Reading of compressed files ('.gz') with Zlib 1.2.8
Gmsh format version: 4.1
Size given for real numbers: 8
Error in preprocessor execution
../../../../src/code_saturne-5.0.9/preprocessor/pre-post/ecs_pre_gmsh.c:346: Fatal error.
Error decoding line 31 of file
"C:......Gmsh\NaturalConvection.msh" :
I appreciate any hint.
Roberto
