I am facing an issue regarding a parallel batch job.
The batch system is SGE.
Although in my script there is the option to run my job in parallel: #$ -l nodes=2, once the job starts running is still serial!
I also tried to add --mpi at the call to run the job; in my case:
I have attached the run_solver as well as the performance.log and setup.log.
I didn’t have any particular messages when submitting neither in the batch log files.
At the moment I am waiting for a simulation to start: I added mpirun at the line of the command of cs_solver in the run_solver.
These are not the type o log files to which I am referring. Batch systems usually add a file (either in RESU/<run_id> or SCRIPTS, depending on how you submitted the file, with a name containing the job number, and extension .out and .err).
Also how do you submit the job ? What does your runcase (including the batch header) look like ?
Files directly from the batch systems are, in my case, with extension .e1385884 and o.01385884 which are empty and I have not attached.
Anyway I solved the problem by adding mpirun at the command to the binary cs_solver in run_solver. I called then the run_solver to the batch script (see it attached).
It looks like the cs_solver by default runs in serial when invoked on their own..
Maybe you can automate this better by defining the mpiexec command choice in the post-install (code-saturne.cfg), since it seems the automatic/default values do not sem to be adapted to your system.
Details on your system (OS version, mpi library version, and current code_saturne.cfg file, ans summary file) could help us improve the default detection (but SGE is always a mess, with a difficult to automate syntax, so I am not surprised)
