Problem with a tutorial
Hello again, i’m recently doing the first tutorial in the site’s section (Simplified nuclear vessel) and i followed every line of the tutorial in the “solution case 1” but i’ve a problem: i finished the compilation and clicked on “start calculation” in the section “prepare batch calculation” and i’ve got this message.
Code_Saturne
Version: 4.2
Path: /usr
Result directory:
/home/mik/T_junction/case1/RESU/20170326-1847
Preparing calculation data
Single processor Code_Saturne simulation.
Preprocessing calculation
Starting calculation
/usr/lib/code_saturne/cs_solver: /usr/local/lib/libxml2.so.2: no version information available (required by /usr/lib/libsaturne.so.0)
Warning: program compiled against libxml 209 using older 207
Saving calculation results
Did i miss something during the installation phase maybe? can i solve the warning message?
This posts belongs in the installation section, so I’ll move it soon.
How did you install the code ? Did you upgrade your system since ?
Hi yvan and sorry for late and for the wrong section. I had installed code saturne with the *.py file. I had some problem during installation ((http://code-saturne.org/forum/viewtopic.php?f=3&t=2071 ← This is the link of when I had problems but thanks to your answer, I solved and installed properly.)) but after installation I do not think I have updated code_saturne or ubuntu itself. From what you wrote in that post, I realized that the post-installation configurations were NOT necessary, so I just tried to follow the tutorial. In the old post that I linked you I wrote a post-installation message that appeared to me at the end thereof. Perhaps I would have to complete those steps?
Do you still have the message you had at one point ?
Hopefully not. You can ignore the message about post-installation: it is just a reminder that post-installation is possible (but is only necessary for coupling with Syrthes or to configure for use with a batch system).
Yes, i’ve got the same message:
I have no idea where the problem is
It is strange that your install is in /usr, unless you forced it that way (it is not the default).
Could you post the information indicated in this forum section’s recommandations ?
I’ve CodeSaturne 4.0.6 on Ubuntu 16.04.1 LTS with:
-CGNS ((from the automatic installer of the *.py file))
-hdf5 1.8.14 (have 1.10patch)
-OpenBlas
-libxml2
-sip
-med 3.0.8 (have 3.1.0 too)
-pyqt
-QT 4.8.6
-Scotch 6.0.4
-metis 5.1.0
-parmetis 4.0.3
Tell me if u need something else and possibly how to get the information because i’m not so expert working with ubuntu.
The useful files (for full info) are listed in the forum recomendations:
http://code-saturne.org/forum/viewtopic.php?f=3&t=12
-CodeSaturne version 4.0.6 (( version of Code_Saturne))
-gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609 ((third party tools used (gcc/icc version, …)))
-cgnslib 3.2.1 ((the other third party libraries are on the previous post))
-i’ve attached the config.log of code_saturne and a file with my system information ((details on system/machine AND config.log and console errors))
System information.log (18.3 KB)
config.log (192 KB)
It seems from your config.lig that you used livxml2 from /usr/local. You probably also have another version of libxml in /usr, and may have the header (.h files) for just one of the 2.
This would explain your message. Why did you need to add another version of libxml2 in /usr/local ? Installing the libxml2-dev packgage should be enough.
I tried to run in terminal “sudo apt install libxml2-dev”. On terminal there was an instruction that tells me to run a command like an “autoremove” in order to delete useless installation files. I restarted the computer and reopened the tutorial case but then:
Again the same error.
Now it only show mee this if I run the command line on terminal:
mik@mik-RC530-RC730:~$ sudo apt install libxml2-dev
[sudo] password for mik:
Reading package lists… Done
Building dependency tree
Reading state information… Done
libxml2-dev is already the newest version (2.9.3+dfsg1-1ubuntu0.2).
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
You probably need to reinstall Code_Saturne after libxml2-dev.
there is a proper way to do it? I don’t want to do more damage and i’m not sure i’m finding the right folder where to write the command line for “unistall”.
Yes, is is better to first remove the libxml2 install in /usr/local. If you can find the directory frow which you installed it, rune “make uninstall”. But if you can’t find it, you can also check the time and date of /usr/local/lib/libxml2.so, and remove all files with that same date in /usr/local (at least /usr/local//libxml2).
Then simply your installation/build directory (the one in which you have config.log and config.status for Code_Saturne) and rerun your installation.
Well, maybe it worked! The installation folder of libxml2 was on my Documents folder and i make uninstall, then make clean and distclean. Then i re-runned the install_saturne.py file and it did something. I don’t think there was any error. Now the annoying script have disappeared. The result is this…
Code_Saturne
Version: 4.2
Path: /usr
Result directory:
/home/mik/T_junction/case1/RESU/20170504-0155
Is this ok? In the tutorial’s image of this phase there are a “Cleaned working directory” line. Am i supposed to have that or is not so important for the results file? I’m becoming paranoic with this :laughing: :laughing:
Yes, this seems good. You can check logs/visualize results/etc at this stage.
Well, thank you very much Yvan. It’s seems to be ok for now :smiley:
Hello, i’m posting here because i’ve again a problem processing an object with CS. I made up the mesh on SALOME and i’ve exported it in *.unv file. ((because the *.med file, during the check mesh phase, don’t seems to be supported by my version of CS 4.0.6))
I’ve prepared everything for the processing and at the final stage “start calculation” there’s this message:
Code_Saturne is running
Version: 4.0
Path: /usr/local
Result directory:
/home/mik/CASE1/RESU/20170527-1223
solver script exited with status 1.
Check Code_Saturne log (listing) and error* files for details.
Error in calculation stage.
What is it?
As the message says, “Check Code_Saturne log (listing) and error* files for details”. Check the listing file in the RESU directory in order to have more details about the error.
Luciano
I hope is this one i’ve attached. Tell me if you need anything about this problem because i’m new with this platform and i don’t know how to check in case of errors like this.
performance.log (211 Bytes)
