yesterday I tried to run my first simulation in Code Saturne but I couldn’t because the “Run Simulation” button was “grey”, not clickable.
I tried to follow the tutorial “joint junction” and the problem was the same.
How can I fix this issue?
Did you create a code_saturne directory structure (either using “code_saturne create” in a terminal or “create new case” in the GUI) ? If your setup.xml file is not in a standard code_saturne directory structure, the GUI will not allow launching it, as the run/results directory is not created/defined).
