I don’t know if I made a wrong installation, but with the new version 7 of code_saturne I do not find the SCRIPTS directory when I create a case. Is that normal?
Thanks a lot for the help,
Kind regards,
Daniele
Kind regards,
Daniele
Yes, this is normal.
SCRIPTS/runcase is replaced by DATA/code_saturne and DATA/run.cfg.
Cases with the old structure will still run, and can be updated using “code_saturne update” from the to case directory.
