I am trying a turbulent wind simulation around a solid, with a Re=2.6e7, as I run the calculation with a rans model (K-w) with no wall functions I get some warnings/errors (see run_solver.log) that I don’t understand. Also I have a question about the general use of user-defined functions, I copied “cs_user_extra_operations-boundary_forces” for instance to my SRC folder in the study. However after the calculation is complete there are no related results to the forces or maybe I don’t know how to get them.
Please find attached the setup and run_solver files.
Thank you in advance for any explanations and help.
If you are a beginner with the code, I recommend generating the boundary forces output simply by selecting it from the GUI. With user-defined functions, you can do additional filtering, summation, … but you need to first have the matching field activated, which is not well documented (but can be activated through the GUI).
Did you adapt the user-defined function to your case (i.e. selecting the required zones) ? Never simply copy an example if you cannot understand its basic steps. Examples are just that. Examples, which usually need adapting to your case/mesh/…
Also, you warnings seem to indicate you are selecting groups “2 or 3” but those are not present in you mesh. This may be related to the paragraph above…
Thank you for your reply. When I run the calculation this time I do get the drag and lift forces after implementing a user-defined function in SRC. However, I still get the following error:
/softs/Saturne/source/code_saturne-8.0.2/src/base/cs_runaway_check.c:244: Fatal error
Runaway computation:
At least one field exceeded allowed bounds (see log)
Does it mean that the calculation diverges? I also tried changing the mpi ranks as explained in another thread.
Please find attached the latest versions of the setup and run_solver files.
Yes the computation seems to diverge.
The code has a safety stop when velocity reaches 10000 m/s as that is out of physical bounds for incompressible flow, and stopping cleanly still allows for postprocessing.
