User defined Particle Diameter Profile
Dear All,
the GUI leads us to specify either single particle diameter or diameters of normal distribution.
I would want to impose an arbitrary size distribution. The EXAMPLEs in cs_user_lagr_boundary_conditions.c do not tell us how to do this.
I know of the inverse transform sampling to generate a random variable for a given distribution. But how to do this in Code_Saturne ?
Is this doable at all?
Anand
There is no reason why this could not be doable. Which version of the code are you using ?
I am using CS V 5.07.
Yes, I found how to do it, although in a less elegant way.
Generate the sampled values from a distribution and store in a text file.
Read the file once for all (using some static declarations) and input those values right into "cs_real_t diam = " for each nbclas and time step.
Anand
That’s ugly. You can do it in a cleaner manner using the cs_user_lagr_in or cs_user_lagr_new_p_attr functions from the cs_user_lagr_particle.c user file.
